No Throttle Output
Bird
Hello.
I have:
Spirit 3
Spektrum ix14
Ar637T RX Connecred via srxl2
CC PHENOIX Edge 160HV
I’m having a hard time getting my esc to arm. There isn’t throttle signal being output from spirit 3. I’m connected to the Aux 1 channel, throttle is enabled in spirit settings, it’s assigned to channel 1 and the slider moves in the channels tab. I’ve set it to 60htz and min throttle range of 1060us and max 1940us per the manual.
For testing, I’ve also connected a servo to aux1 channel, the servo does not respond to any throttle input either. I’ve tried adjusting my min and max endpoints in my TX, that did not help either. I’ve triple checked throttle is enabled and the spirit is receiving a throttle signal from my radio.
Any help is appreciated.
The problem is usually in enabling Castle telemetry with no Castle telemetry cable.
It is enough to turn ESC telemetry off until it will be configured for this telemetry at both sides and you have our Telem CC cable.
In Advanced/ESC telemetry you can do this change. Default is Disabled.
Bird
Disabling telemetry worked. I will verify telemetry works once I get the proper cable and live link is enabled in esc settings.
Thank you.
