Spirit Fly (built in sim app) has sound randomly starting and stopping
Nuclear246
I was the one that was having the Spirit Air simulator app crashing all the time. I just now realized that there is sound? This whole time I thought there was no sound. On a rare occasion it somewhat partially drops a frame or two and the sound kicks in for a split second, then the sound cuts off again. I am happy with it and will still utilize the built in sim App.
I just figured I should let you know, because you can’t fix what you don’t know is wrong. Thanks for your attention to all the Spirit system users and their needs.
Sincerely,
Chris
the sound volume is adjusted by left potentiometer. Is this working normally? Was it changed or moved in some way? I am afraid there could be something wrong with your Wave, the most likely some wiring. Possibly after doing some internal changes something does not fit well. I would check the 16 pin flat cable.
Have you removed some switch by chance?
Nuclear246
Thank you for the response, my wave radio has never been apart. It was brand new when I bought it from HeliDirect. By turning the left knob you talked about, the sound now works! Thank you very much. It is working, quite a bit better with audio! LOL
Very warm thank you!
Sincerely,
Chris
