hobbywing platinum 260a V5 telemetry problem
kostian34
My setup:
FBL Spirit GT (version 4.0.2)
RX Radiomaster RP3-H
TX radiomaster tx15 max
ESC hobbywing platinum 260a hv sbec v5
Problem:
The Spirit app on my PC doesn't display some telemetry: BEC current and BEC voltage. Headspeed is also displayed incorrectly (even though the data is correct in the HobbyWing app). Furthermore, when transmitting telemetry to the receiver, more telemetry is lost: headspeed and temperature. So, all I see on my TX15 is the battery capacity, current, and voltage.
What could be the problem and how can I fix it?
please note the Current and Capacity is measured only with a certain load. Because ESC can't sense small current (case with blades off). This is limitation of the ESC itself, but in the air all should be OK.
Regarding RPM you need to set correct Gear Ratio and Sensing Divider in the Spirit unit.
