4.0.3 -weak damped head
Posted: Tue 12. May 2026 6:30:53
by Christian
I am about to setup my first helicopter on Spirit W3 @ 4.0.3.
- weak damped head (70° rubber rings, from Nimbus v1)
- classic head geometry, not 1:1 (from Nimbus v1)
The 4.0.3 is already much better than the 4.0.2 which I run with Spirit RS before. But, I wished it would be more precise, more stable against wind. I was wondering which of the setup parameter is most important for weak damped heads:
Any suggestions? Maybe a weak damped head will never be as stable/ loggin-in as it is known from stiffer heads?
Thank's and best regards
Christian
Re: 4.0.3 -weak damped head
Posted: Tue 12. May 2026 7:43:59
by Christian
Some more information on what I did: flew the very first 3 batteries on 4.0.3 yesterday.
First, reduced the Elevator Filter from 3.0 to 1.5, because it seems so damped on elev. in comparison to roll.
Feed Forward is still at 4 (default, class 600 heli)
I raised the Head gain (cyclic sensitivity) up to 80%, but starts to be shakey. Went down to 70%. What I have known so far, 80% should be possible with weak heads. I prefer the feeling of 80% and using this on all my SAB helicopters, which have 90° damped heads.
Finally, head speeds around 2000-2100 feel much better to me than 1600-1800. The higher head speeds feel, of course, more acrobatic. I am struggeling with the head speed below 2000. It feels so unprecise and unstable to influence from wind.
It was 3-4 Bft wind, yesterday.
What can I do to make it more logged-in? Maybe changing the dampening?
Posted: Tue 12. May 2026 7:47:02
our piltos are flying much lower RPM with Nimbus, but very different adjustment is needed.
Mainly you can increase stability and precision with higher Swashplate - Integral value.
If you can share your settings file, I can check all parameters.
Posted: Tue 12. May 2026 8:19:57
by Christian
Hello, thank you for your quick reply.
I will try the Integral value. Attached you will find my current setting.
