Aux channels are always on?
Echobulb
Just bought a Spirit GTR, set up all the servos on the head, tail & throttle Ok but have had unsurmountable issues with the Aux0 & Aux channels, the're always outputting 'on' to the onboard glow driver?
Flicking the switch on the channel to -100/+100 has a small effect but glow is always on. Adjusted the end pints in the radio with no success?
Have thoroughly been through the setting multiple times, Jeti DS12 has Spirit software installed, the output on the radio channel is working both in the software and on the radio, however the glow plug is constantly on?
Have confirmed the glow ignitor working normal when reconnecting to original Jeti RX -
Any thoughts?
If I can't find an answer it will be retuned?
first please make sure that Throttle channel is assigned - this is required for AUX port to work.
Then you have to set F: Output to AUX function in the Channels. Then you can verify that it works by connecting servo there. If it will move, it will work.
Glow plug might require low frequency - 60Hz. You need to set Throttle frequency to 60Hz only.
Echobulb
Thanks that has worked - fantastic :D :D :D
