6degree tuning
Posted: Fri 19. Jun 2026 23:16:14
by gordo
So when I tick the 6 degree box I immediately see the left pitch servo drop and only this one. Is this correct? I have gone thru all the other stages and I thought this was the last thing to accomplish however I could only get to 8 percent even though I,m not sure if this function is supposed to work this way. I might have been able to get to 6 but the numbers would not let me get to what the highest number allowed. Please advise, thanks
Re: 6degree tuning
Posted: Sat 20. Jun 2026 1:17:43
by gordo
Does anyone know the size of the wire on the ball link and the thread size? Its a Trex 600. After thinking this over I believe that is the only way to fix this by raising the swash plate a small amount and I'm not sure if I can unwind the thread enough and still be safe. If I can find the size Ill buy some stainless wire and run it thru a die. If I'm way off I hope someone will steer me right.
Re: 6degree tuning
Posted: Sun 21. Jun 2026 17:10:07
by gordo
I;m having a time with this 6 degree geometry. I redid the whole head and It looks perfect to me however at the lowest slide adjustment I'm still at 7 degrees. What in the world do I need to do my brain is hurting. I'm assuming this is done at 0 degree stick centered? I would appreciate some guidance, thanks
Re: 6degree tuning
Posted: Mon 22. Jun 2026 10:19:02
first you need to set precisely Subtrims. This is done in the Subtrim (tuning) menu. When entering the menu, all servo arms must be in the center as close as possible, swashplate should be perfectly level and there must be 0° between main blades.
Only after this step you can correctly set Geometry 6°.
Re: 6degree tuning
Posted: Sat 27. Jun 2026 21:00:13
by gordo
i have gone thru this 6 times and very carefully. I just find it hard to believe I'm the only one who can not figure this out, On some occasions I had 7 degrees and others it was 8. There must be something I'm overlooking but I have read the material over and over and I always end up in this same place. Honestly I am whooped and beaten and just about ready to give up. I'd like to say it's been fun but I'd be lying. This is my last attempt to gt help. I have gone thru these sequences so many times I can see them on my head so Yes I am precisely doing exactly the steps that are necessary. My only wildcard is the fact that I am using an aftermarket fbl head unit and after failing over and over I decided to do what others have done and I took 11mm off the main and re-drilled for the head. Although it looks right I still get the same results
Re: 6degree tuning
Posted: Sat 27. Jun 2026 23:12:50
by Mattes61
short question did you made the 6 degree on both sides ? - that's not necessary ! you should get always 6 degree -
If you get on the other side 7 degree so that could be that your blade is 1 degree off, so you have to adjust it that it has also 6 degree -
Last to say it is absolutely necessary that all servos are centered and the blades have at this point 0 degree pitch before you adjust the geometry of 6 degree at one blade oriented to the boom. For pitch-adjustment also oriented to the boom -
Then all should work and if not then its a problem of the cusom head and the geometry
BR
Re: 6degree tuning
Posted: Mon 06. Jul 2026 1:39:18
by gordo
Thank you for trying to help but I finally figured it out. Seems as though my servo horns needed to have the balls closer and that is all it was. I now get 6 degree at 96. As much as I read I can now see that the developers know about this, would have been nice if they would have mentioned that in the standard instructions. I will say they have written up a world of instructions but it is quite a job sorting thru it all. If I decide to do my other 3 helis I will definitely have a head start. It seems as though all the fbl units of brand x use this 6 degree tuning and It Is important so do not skip it.
Re: 6degree tuning
Posted: Fri 10. Jul 2026 17:32:03
by Mattes61
good that you found the problem - but it would be easier for us if you showed an hardcopy that you didn't get the 6° because of limiting in the software...
The help would be easier and faster that you have only to change the distance on your servo horn to the inner side as you said -
BR
