[ Spirit Aero 1.9.0 released! ]
Check out the news about the Spirit Aero.
Version 1.9.0 - ChangeLog:
It brings many new features and improvements:
  • Spirit W3 support:
    • Added support for Spirit W3 units.
  • YGE ESC Setup support:
    • Compatibility with the latest YGE ESC firmware was fixed.
    • The ESC will work out of the box with full Telemetry and Integration support when using Spirit Wave radio.
  • New Scorpion ESC Setup support:
    • From now all Scorpion Tribunus ESC can be directly configured through Spirit Wave radio.
    • Wiring require no change from Scorpion ESC guide. Only Telem UNI cable is required to make it work.
    • Make sure that Spirit Wave is updated to the latest 1.0.25+ firmware.
  • Scorpion ESC telemetry:
    • Added support for Scorpion Tribunus III.
    • Setpoint and PWM telemetry variables are available for Spirit Wave.
  • ESC telemetry - Kontronik TelMe:
    • Added new data checking for all telemetry frames.
    • This will avoid displaying and logging incorrect values.
  • New ESC telemetry - FlyRotor:
    • All FlyRotor ESCs are fully supported and can display ESC telemetry.
    • All Spirit units except v1 have this support.
    • Wiring can be done through Telem UNI cable at the SAT1 port.
  • ELRS/CRSF telemetry:
    • New telemetry variables that carry RPM and Temperature natively.
  • Spirit Aero PC software:
    • User Interface was reworked to improve navigation through the menus.
    • Menu Tabs were relocated to a Side panel.
    • Minimize and Maximize window buttons are displayed on Windows and OSX now.
  • Spirit Aero Theme:
    • You can configure App Theme in the Configuration - Appearance window.
    • Available themes are:
      • Default
      • Dark Yellow
      • Dark Red
      • Dark Blue
      • Cocoa
    • Mac OSX will use theme Cocoa by default.
    Update for the Spirit units is available in our Download section.
    NOTE: No need to reconfigure any parameter after updating from 1.8.1.
