Auto Rescue (hard deck) setup questions
aerosheldon
Hello. Using GTR with Jeti.
Can someone explain, in detail, how to set up the automatic stability (rescue) and how to use it? I can see on a dropdown under STABI tab to turn it on to enable, but have no clue how to set it up (switch?) or how to use it in practice.
I did get it setup by the manual (I think) but not sure if it should be a 0 to 100 value on the switch? And if so, is 100 the value to set the deck and 0 how I turn it off to land, etc??
aerosheldon
I think I can get most of this but really need to know the values and which value is off and which is on.
Konrad
This video of Pascal Richter can probably help you: https://www.youtube.com/watch?v=xkOxHRp376Q
There are english subtitles if necesssary.
aerosheldon
Konrad wrote: Thu 06. Aug 2026 16:19:22 This video of Pascal Richter can probably help you: https://www.youtube.com/watch?v=xkOxHRp376Q
Thanks! I will go watch it straight away.
