Collective doesnt work
Teejay
To this day, no problems with the Logo 600 with Spirit GT stabilization. Today, after starting and hovering, the model stopped responding to the collective. After landing with autorotation, the collective was dead to movements with the lever from the Spektrum transmitter. At home, the leaves were removed and almost everything was tried. The collective always works for minutes in hold. After starup motor after about 5-10 full movements of the collective min. and max., the collective randomly freezes. Even in the program, the thermometer in the diagnostics tab does not move. If I put Hold back, the collective is already frozen and does not respond. Please advise what else to try. Rescue is not activated, I also tried disabling it in the program. Returning home from geolink is also not active.
Everything worked, I took it off the shelf after a week and now this. The defect always appears.
delta peak
Are the servos powered when collective freezes, can you move them by hand?
What do you see on the transmitter servo output?
Is Spirit LED on when collective freezes?
