Help with CCPM 90 deg swash - 3 servo version
Bladecrasher
Hello, I'm on 4.02 on an original "red" Spirit. I'm trying to setup an ancient Ikarus Eco 8 to use the Spirit, and am confused.
It seems like the servo arms are not moving correctly.. I have the DX9 on a Normal swash. You can see in the video link how the servo arms are moving.
https://share.icloud.com/photos/0637Snk ... bZdll3n2fQ
When using a Lemon and a different model in the DX9 using the Spektrum 90 deg swash, the servo arms move correctly, see link:
https://share.icloud.com/photos/04bkgBM ... BBHFasdiNw
What I'm doing wrong or confused about?
Thanks, Rick
delta peak
Was Spirit mounted on a plane previously?
it looks like there is Aero firmware flashed and not Heli firmware.
Bladecrasher
I will double check and maybe flash 4.05 heli on it to see what happens. Thanks for sharing a possible error on my part.
Bladecrasher
This may be resolved. I did a Factory Reset of the unit and then set it up again, and it seems to be working normally now.
