Help with step adjustment on different banks
mascio
Good evening. Can anyone tell me why, with the stick at 100% in Normal mode and Bank 2, I get 11 degrees of pitch, yet in Bank 1 it barely reaches 8.5 degrees—even though both the stick and software settings are at 100%? I'm using a Radio Wave setup with a Spirit W1. Thanks in advance to anyone who can help.
delta peak
When you go to Limits tab, is the value of collective pitch the same for all banks?
mascio
Yes, it's the same for all three... It's a very strange thing. Thanks for the help, by the way.
Please share your settings files for all banks, then I can tell you exactly what is wrong.
mascio
Grazie mille per la pazienza penso di aver risolto ma ora mi manca la configurazione del rescue automatic . Puoi controllarmi gentilmente iei file l' attivazione del rescue automatic ? Utilizzo RU ma mi dice che e attivato ma sull lcd non esce scritto impegnato ma se cambio interruttore funziona ma non capisco se veramente funziona perchè il piatto ciclico va su e giu a distanza di circa 3/4 secondi.. Grazie mille
bank 2.4ds
(255 Bytes) Downloaded 142 times
bank 1.4ds
(255 Bytes) Downloaded 139 times
setup spirit.4ds
