Jeti and Spirit 3 channel assignment/ unable to assign channel 8 in Spirit Settings SW
Posted: Tue 27. Oct 2026 9:02:39
by ste
Jeti DS-14 connected with EX-Bus to Spirit 3
All configurations done with Windows Spirit Settings V4.0.5
With the help of Spirit Settings I've assigned 7 channels (list is not in the assgnment order) :
  • Throttle
  • Tail
  • Pitch
  • Nick
  • Roll
  • Gyro sensitivity
  • Rescue
So far so good.
No I would like to add bank switching, to have on Bank 0 the manual throttle (its a Nitro) and on Bank 1 the rpm control.
BUT: The Spirit Settings does only provide the possibilty to select Channels 1..7 which are already used. There is no selection possibility for a channel number above 7 which would be needed for the bank switching.
I'm confused:
  • Is my Transmitter setting wrong, and maybe the Bank Channel is not yet send to the Spirit?
  • Or is there a bug in the Software?
  • Or ist there something else (maybe me) which causes the issue?
Any help is appreciated.
May you have a gentle landing...
Re: Jeti and Spirit 3 channel assignment/ unable to assign channel 8 in Spirit Settings SW
Posted: Tue 27. Oct 2026 10:26:46
by Phil S.
Did you create an appropriate channel on your TX under "MENU - Model - Functions Assignment" already?
Regards Philipp
Posted: Tue 27. Oct 2026 11:54:01
unfortunately channel assignment is probably not correct, all channels 1 - 6 should be unchanged at both sides in JETI and Spirit. It is enough to create Spirit model in your radio - this will create channel layout that will simply work out of the box that will simply work.
Then you can assign Channel 7 to Bank Switching. This is normal way how JETI users are doing it.
