Gov and Revo Mix - should we look to adjust this?
scornflake
With the new update, if we now use the Spirit Gov & we've already got revo mix in place, will this require any reduction?
I've not actually had a chance to fly with the gov enabled yet, but thought I'd ask in case it's something I should keep in mind.
Normally we do not recommend using revomix at all, but it is likely that our governor can have positive impact on the rudder performance so revomix value may be decreased.
smgunn
I did have to start using the revo mix when I started using the gov. But the heli is locked in solid. I'm very happy with it
Djg24
I had the opposite. I was using 1-2 points of revo mix before setting up the governor. Once I set up the governor, I got rid of all revo mix and the tail is as rock solid as anything I've ever flown.
smgunn
After tuning the gov a little more I've reduced the revo mix. Though the governor sounded like it was holding the head speed great I was still able to raise the gov response a little more and now the tail hardly kicks at all in a full pitch pumps and tick tocs.
Goblin 380
KDE500XF-925-G3
HobbyWing 100a Platinum V3
KST-315MG/KST-515MG @8.4v
21t pinion
Headspeeds: Norm=2700, IU1=3000, IU2=3250 rpm
Gov Response 7
Holding performance 4
I couldn't be much happier with my Spirit.
