I am interested in adding the bt module. I have two Dsmx satellites. My aux channel has
My esc with the red wire disconnected. The rudder channel has a y-cable with the bec lead and the adapter for the second satellite. Where can I plug in the bt module? I could do another y cable and plug my esc into one side and the bt signal lead into the other ( both plugged into aux) but where do I get power for the Bt module? Thanks
Bluetooth module where to plug in [SOLVED]
Jamisonchang
Jamisonchang
My apologies. I made a mistake in my above post. The signal lead of the bt module would go into the sys port. Could I then plug the power lead of the bt module into a y connector (the other half has the esc plug with the red wire disconnected and both plug into the aux port of sprit ). Will that work? Thanks
Yes, it will work.
Connection scheme is in my acttachment
- Attachments
- btscheme.pdf
- (38.8 KiB) Downloaded 281 times
