Rsat2 connection
mallen
Can I just check I understand this correctly?
To run UDI with a Jeti Rsat2 I connect to the EXT port but Jeti instruct not to add power to EXT.
I don't want to damage the RX.
"Connect the unit with special cable - you can made it yourself with included ELE/PIT/AIL cable in few seconds (check attachment).
One end of the cable should be connected directly to the EXT port. Opposite end has two connectors. One with power supply wires (RUD port) and one with signal wire only (ELE/PIT/AIL port, respectively AIL pin)."
Mark.
EXT connector is used for EX Bus connection or telemetry sensor, not UDI.
You have copied phrase from EX Bus connection that allows integration with the unit and JETI transmitter.
UDI is different connection type that does not allow it, but connection is easier - just normal cable.
mallen
Yes, I found the different information very confusing but got there in the end.
Flew my 600 pro at the weekend with basic settings and only changed the flight style to 7 which suited my flying and felt more like the Vbar I removed.
Have to say, the heli was rock solid and very smooth, I'm very pleased with how it flies and the ability to quickly change settings without a laptop at the field.
Big thumbs up from me. :D
Mark
buttles
Mark, from reading between the lines I assume you are now using Exbus? Have you checked your Failsafe? Known issue at the moment with Exbus and Spirit.
Thank you very much for the info!
mallen
buttles wrote:Mark, from reading between the lines I assume you are now using Exbus? Have you checked your Failsafe? Known issue at the moment with Exbus and Spirit.
Correct I have test flown this with Exbus and failsafe did not cut the motor. Will be changing this for future flights until a fix is available now that I know it flies well. Hope something comes soon.
Small update to address the issue will be released this weekend :)
mallen
That would be fantastic, I will hold off changing anything.
SJo1
Hi Tomáš,
I found that new fw 1.2.1 was released, but changelog hasn't updated?
Could You please chime what fixes this new minor update contains:)
Sami
you can find changelog here on the forum in News/Version 1.2.0 released and also in the software after updating to the latest version.
