Low head speed on Synergy E7SE
johncclayton
Hi
Is anyone flying low head speed on an E7(SE) and also using a Spirit FBL? If so I'd be keen on hearing what FBL settings you are using as well as the size of main/tail blades.
I'm targeting a range of 1100 (6S setup) through 1500 (12S w/low throttle signal value). So far I'm running 696 main blades and 106 tails but will be fitting 716 mains and 116 tails at some point. Engine is 4525-520.
--John Clayton
John Clayton
I believe that there is no special settings needed. Only problem may be with the rudder settings, where you could need revomix little bit.
