[SOLVED] Jeti DS16/Spirit - Device is not recognised
Malc1
Just started to attempt to get my new Spirit unit to work with my Jeti DS16
As per the instructions I have copied the Spirit.bin file over into the devices folder on the transmitter but when I try to enter the setup I get the 'Device is not recognised' error on the Jeti screen as per one of the other postings on the forum here.
There was no solution actually posted for this other than check step 6 which is just to copy the file on to the TX.This has been done.
Any further ideas please?
File names are case sensitive so it is important so that it is named in the very same way.
Make sure that tx and rx is the latest version.
Integration is on the videos from Esprit model.
Malc1
Now sorted and working OK.
Original .bin file deleted from folder in TX and new download added instead.
Thanks.
