[SOLVED] Module bluetooth order1098
Posted: Mon 29. Jun 2015 16:58:52
by Gilbert AINEE
I hope my post is well placed .. I received my spirit Module BT today my xperia can connect to the BT module, against it is impossible to read data from the Spirit module.
I tried the PC via cable, that's OK, not via BT module
what to do ??
Re: Module bluetooth order1098
Posted: Mon 29. Jun 2015 17:11:54
maybe you are using external battery to power the module.
If yes, then you have to connect grounds with BEC (black wire).
If the power is completely separated then it can't work together with the unit.
Posted: Mon 29. Jun 2015 17:24:42
by Gilbert AINEE
actually, I unplugged a servo to turn moduleBT, then an update of android software and it works perfectly
a big thank you
Posted: Mon 29. Jun 2015 17:29:07
Perfect. You are welcome.
