Hello There,
I need some help with the Gov. Settings for the combination
Spirit Gov + HW + Platinium 50aV3 Xnova XTS 2618 1580KV
Here is a log with slight pitch Pumps, as you can see The speed drops dramatically. The current Gov. Settings are 4/4. Who knows what?
Björn
Gov Setting Hobbywing Platinium 50a Xnova XTS 2618
- Attachments
- GauiX3_HW50aV3_XnovaXTS.pdf
- (36.08 KiB) Downloaded 195 times
Gaui X3, Gaui X7
I recommend to increase Governor Response value. At the same time, you can initially configure Holding Performance to 1.
This method is also described in the manual as second one. While increasing Governor Response RPM should be more constant while doing pitch pumps.
