450 Mini Titan Flybar
Posted: Sat 04. Jul 2015 18:01:56
Hi
I've set my Mini Titan Flybar up with the Spirit unit and 2 x Spektrum Sat Rx and Taranis radio.
Maiden her today after I took the old gyro off.
Pls. See the settings on Bank 0......normal mode.
Take off was okey, but the tail keep on wagging. The tail gain is (I can set it on the radio) between 50 to (60 ) to 70.
The gain changes made no difference.
The Helli was okey during flights, but also drifted to the right a bit ?
Can you maybe help with this ? The tail also needed left input ?
Can one use subtrim on the radio to trim the Helli during flying with the Spirit ?
Also, what other reasons can there be for the tail wagging (it was more wag than Ossillation), .... something that was'nt
there with the old gyro ? The servos are all analog....the tail servo is a Hitec HS 81.....should i change that to digital ?
Thanking you.
Agarob
Any advice and setup tips would be appreciated.
Thanking you.
Agarob
