Goblin 380
Russell
Hi all. Setting up a G380 with BK servos all round I intend to run 2800 3000 3200 HS.
Can anyone recommend a starting point for head & tail gain and piro comp.
Russ
Hi Russell,
I recommend to start with default values, these are the best for the beginning.
Piro Consistency should be somewhere between 160 - 175 depending on your tail setup.
Russell
Thanks Tomas can you advise what the default settings are for the G380 I don't remember seeing a preset for this one to use as a starting point.
Generally you do not need to change anything special from Default profile settings. Only Piro Consistency, Rudder Delay and Geometry 6° should be configured with respect to your model.
If you can tell me what rudder servo do you use, I can tell you more accurate values.
SJo1
Russell is most probaply using BK 5005hv as tail servo. Or atleast I have it, as per manual show it too[WHITE SMILING FACE]
Then the Rudder Delay can be configured to approx. value of 2.
Russell
Yes Bk servos all round....I will try you suggestions.
Thanks Guy's
Russell
Running 2800 3000 3200.
At 3000 the tail is perfect. Getting a slight wag at 2800 and 3200.
I have inspected the tail and made it smoother next I will check gov gain and see if this helps.
Russ
