Jeti headspeed RPM telemetry
FrankFuss
Would it be possible in a future release to include the headspeed RPM in the Jeti telemetry when the Spirit governor is Disabled?
Yes, it is possible.
If you are not using governor and the throttle is not connected to the unit, you can measure RPMs with governor enabled without any problem right now.
FrankFuss
I do have the throttle connected to the Spirit unit. I was hoping to get RPM telemetery in this case with the governor both enabled and disabled.
