[SOLVED] BT and v 1.2.1 ?
Dawiev
Hi, I upgraded the firmware to 1.2.1 and now the BT module doesn't connect.
Before I revert back to 1.2.0, is there something I need to do to make it work in a new release ?
error414
android app should be work without trouble with 1.2.1 version.
What does it mean "doesn't connect"?
Logo 600 3D -> Spirit FBL
Spirit settings Developer
Dawiev
Thanks for the reply.
Device is paired. On the connection screen it connects but the serial and firmware fields stay "unknown". When I move to the next screen it pops up a "reading data" and then posts a connection error and stops,
Most probably your BT module is not connected properly to the SYS port or you are powering the module from external battery, not same as the unit.
Dawiev
Oops !! Where's the smiley with the red face ?
Powered it from a different battery. All's good now. :D
