BT connection and mac OS X
Capelini81
i´ve searched a while but didn't find an answer for my question: Is it possible to connect Spirit via USB to OS X? I can connect to the Module but then it ends cause the Software can´t find a port to connect...
USB connection is fully supported for OSX, Windows and Linux.
BT module connection is officially supported only with Android at the moment.
With some knowledge it should be possible to connect BT module to a computer too, but we do not recommend it at the moment.
Capelini81
Thanks for the information.
Will it in the future be possible to connect via BT? I use the Spirit in a Scale Heli and it would be a bit more comfortable ;)
Is it a Problem to let the USB adapter connected to the unit during flight?
Greets
Yes, it is very likely.
I recommend to use cable extension so you can connect USB interface anytime you want comfortable.
BT module can be connected during flight, but we are not recommending because of possible interference with radio and risk from other people that can change your settings. So the cable extension should be very good.
