Nitro Throttle fully closed trim position - tx setup
Malc1
Addition setup help with reference to my other thread.
Is the correct setup procedure for this to have the throttle to be fully shut at 0 trim position on the transmitter or a - trim value below this?
My fully closed throttle trim position is currently -40.
I normally raise it a few points towards 0 to get the engine to idle.
Just wondering if I need to adjust my TX's throttle channel end points to give the 0 - 100 throttle in the software with the throttle trim at 0 and then use the governor min tab to fully reduce it further to close the throttle fully?
Just clarifying a basic setup point - to be sure.
It will work in both ways. There are no special requirements.
Malc1
Ok thanks.
