Problems with Hobbywing RPM Sensor
ThePurpleKnight
Today my Spirit arrived and I think until now it is perfect for me after only a little testing. But I have one Problem with the RPM Governor. I got all the settings in like Gear ratio and rpm but when switching the motor on I get no rpm shown in the gov. tab. The motor spools up but nothing else happens. I already tested the sensor with my multimeter and it shows about 2khz frequency. Is this normal?
I plugged the black and red cable into my reciever and the white cable in the middle of the ELE/PIT/AIL port.
Don't know what my problem is. :evil:
Greetings from bavaria
TPK
kmaluo
My spirit did the same thing at first when setting it up. I rebooted the Spirit and reconnected my android phone, then it started showing rpms.
Coco66
+1, exactly same here
ThePurpleKnight
Thanks! It worked after a reboot of the spirit for me too. Maybe Tomáš should add that to the manual or into the software like with the switching of the SUMD mode where you need to reboot too.
greetings from bavaria
TPK
