stabilization during a loopings
ramaa0211
i have a problem with the stabilization.
when i want to fly a looping (with stabilization)and i am shortly befor the invert flight (nearly 11 clock) the heli proposes to abruptly.
Is this normal?
for doing loops with Stabilisation you need to set Acro option. When you are going from normal to inverted position you will feel that after certain point it will try to keep you in the inverted position and vice versa.
For doing stationary more flips or more acrobatics we highly recommend to use conventional flight mode + rescue together. Stabilisation is used for learning basics/scale flying but as soon as you want to learn tricks you should disable it.
