swash plate moves back to center position very slowly
scvflyer
Hi to all and service team, could be that wrong settings are the reason for it. It hasn't flight because I bought it few weeks ago and now I'm starting to assemble it with my TREX 550.
The behavoir is - If I move the stick (elevator/aileron) to it's maximum everything is fine (looking at the speed). Removing the stick to it's center position it needs 2 or 3 seconds until swash plate is in center position as well.
Wrong setting? A unit issue ?
thank you and br Siggi
Coco66
Absolutely normal behaviour for an FBL unit...
yes. This is very correct behavior.
scvflyer
Thanks for quick answer
br Siggi
