Throttle travel adjust if using Jive Pro gov?
Posted: Sun 13. Sep 2015 5:59:24
Trying to get an idea of the best way to calibrate the Jive Pro throttle endpoints and program mode 4. I have the master/throttle cable plugged into AUX in the Spirit, and get movement in the diagnostics screen. I've adjust travel to get all the other channels to -100 0 +100, but assume I should just leave the throttle end points in the Spirit alone? They're a ways off from being -100 0 +100 like the rest of the channels. It's just passing the throttle signal right through to the Jive Pro correct? Would I be better off adjusting the travel to -100 0 +100 in the diagnostics tab, and THEN programming mode 4/throttle end points for the Jive?
Thanks!
Thanks!
