Connecting Graupner GR24 with SUMD signal to Spirit
scvflyer
Hi Serviceteam,
just to become save - how must the GR24 be connected to spirit if i will set my receiver to SUMD signal . Is it right, that it's correct to connect it only to spirit's RUD Connector?
thank you and br Siggi
yes, you are right.
It should be connected in the very same as with SRXL/SUMD connection type (scheme in the manual).
Do not forget to set SRXL/SUMD receiver type in the software to make it work.
