Something about setting - here diagnostic tab
scvflyer
Hi Serviceteam,
1) Is it really needed to reduce servo's way? Setting it to -100 / +100 in spirit system - Transmitter's setting for servo's way is not more than -80% /+80%.
2) Because I'm using TREX 550 with flybar - is Flight style 4 at general setting okay ?
3) I would like to use the rescue system and bank switching. Because there is only one connector at spirit system for these functions I would try to use transmitter's function like mix signal for bank switching and signal for negative gyro gain to activate rescue process. Is that the best option ?
thank you supporting me and
br Siggi
1) It is not absolutely necessary, but it is recommended. So the input for the system is somehow unified and with for example rotation rate 8 you will get same rotation with other radio too.
2) yes, it will work fine. You can use any value.
3) There is one channel for Gyro Gain and second can be used exclusively for Bank Switching. So everything can be separated.
Mixing is the last option, it is not necessary at all.
The best is to configure momentary switch to change Gyro Gain from one value to another that will be negative (inverted value of your flying gain).
