Governor setup - Sensing Divider?
MyRCode
What does this parameter do? What should I set it to for my Gaui X3?
I'm trying to setup the Gov for the first time wiht the RPM wire from a Castle Edge
djhandz
Think its to tell gov how many poles your motor is so gov can give correct rpm. Divide motor poles by 2 and thats the number you want to enter
Compass 7hv v2 spirit pro. Compass 7hv v2 spirit pro. Trex 550fl spirit. Heli-x sim. NeXt sim. Pheonix sim. Fms p51 1400 spirit. Coolice 2400watt psu. Pl6. Icharger 206. Peter lynn twister 5.6. Dx9. TM1000.
Yes, you are right.
You can find description in the manual and also in the software just by hovering mouse cursor above any parameter.
MyRCode
ZeXx86 wrote:Yes, you are right.
Thanks... I should have checked the manual.
Do the pop ups work on Android? I can never seem to get it to come up when trying to hit the ? around fields.
Coco66
Keep the item pressed and the help will popup.
