Version 1.3.0 released!
Posted: Wed 30. Sep 2015 19:58:40
Version 1.3.0 was released!
It brings many new features and improvements:
New JETI Binary file is available here:
http://spirit-system.com/dl/jeti/Spirit.bin
- Spirit Pro support!
- New sensor data processing.
- Improved flight behavior and precision.
- Improved Governor:
- Max. parameter range was extended (has to be reconfigured).
- New feed forward algorithm for immediate response and superior performance.
- Support for more sensors.
- Spoolup rate can be configured with higher precision.
- Governor is activated at 40%+ TC.
- Governor can be enabled/disabled between banks (check settings between banks!).
- Improved bailout feature.
- Throttle settings are available for disabled governor too:
- Frequency can be configured to obtain much better performance.
- Throttle Range - Max. value can be configured to 150 for disabled governor.
- Channel Mapping was improved to display current channel values.
- Improved Wizard:
- Saving of the settings is available anytime with CTRL+S.
- Unit can be disconnected anytime during the process of setup.
- BEC tester was improved to determine if the power supply is sufficient.
- New bank comparison feature.
- New bootloader.
- New secure format for the firmware.
- New firmware flash procedure:
- Much more secure (encryption, data integrity verification).
- Firmware can be flashed easily even when any kind of failure occured previously (with the new recovery mode).
- Improved Rescue and Stabilisation mode:
- Stabilisation hovering level can be manipulated to a higher extent.
- Rescue (Normal) has 1.5s climb out as with Acro mode.
- Improved precision with more level corrections.
- Improved UDI protocol compatibility.
- Support for next channel in PWM connection with Spirit Pro.
- New Rudder end-points setup.
- Additional features with Spirit Pro..
- All settings from the previous version are untouched. You do not need to re-configure anything.
