New Firmware - what to reconfigure?
Malc1
I've still not test flown my new TRex 700 Nitro due to issues reading RPM's and therefore uneven engine speeds.
If I flash the new firmware before I test fly again what do I need to reconfigure?
Anything?
You do not need to do any reconfiguration if you are not using Governor from the unit.
If so, then you will need to re-configure Max. parameter, Spoolup rate, Governor Response and Holding performance and to enable Governor in the Bank you wish (mostly all banks).
Malc1
Yes I will be using the Nitro governor.
