spirit 1.3 gov setting
walle999
Hi there i wonder what the refresh rate should be on castle edge series speed controllers it say on there home page "ESC now supports, and USES, high frequency receiver pulses (100+ hz). In previous versions of firmware, receiver input was processed at 50hz." from version 4.0 and higher, but what value should i use in spirit gov. can a to high value damage or make any illeffects if its not supported by the esc?
Best regards
Niclas
ESC shouldn't be damaged, but some problems may occur.
Mostly it is strange spoolup behavior if there is any used by the ESC.
I recommend to not use higher frequency than 200Hz for any ESC and examine if it is not too hot.
