Software and firmware 1.3.1
keithw123
Both updated with timer for acro mode rescue.
Thanks Tomas.
Coco66
That was fast!
Diky Tomáš !
TSchwyn
Great turn around time! Thanks Tomas!
phwm
The timer is defaulted at 0.1s [emoji106]
buttles
Hi Tomas, is there going to be a 1.3.1 file for the Jeti system? Thanks
Badger1666
do I understand this right ?? , normal mode works as it did but with a adjustable timer ,that limits climbs out to time limit then switches off bailout. ?
acro mode will level to either way up which ever is quickest climb out to set time limit and if its inverted flip to skids down when time limit reached ?
not that I can find a timer in acro rescue mode , why does it not also have timer
Coco66
No.
Normal mode will level to inverted if it's faster, climb up for the set time, then flip skids down and keep climbing until turned off.
Normal mode when leveling to normal and Acro mode are both unchanged.
MyRCode
Coco66 wrote:No.
Any one know the delay for the flip when in normal mode? I have rescue set to acro but want to try the normal rescue + flip. I've got it on a momentary switch so I'm curious to know how long I need to hold it down.
Badger1666
thanks ,so there is no point in having acro mode rescue now then if normal mode corrects your inverted mistakes
Badger1666
just push and hold until it flips, the time until it flips is what you set it to.
MyRCode wrote:
Coco66 wrote:No.
