[SOLVED] Mounting vertical
Scott H
I have the unit mounted vertical (the antenna ports are facing up and down), wires are pointing to the right when looking at the heli from the rear.
Other than setting vertical in the General tab, will I need to do anything different in the set up?
I ask, because when I trigger rescue the swash tilts hard to the right. Turn rescue off and the swash levels.
In addition, I have stabilization set on another bank and when I trigger that the swash stays level.
I will be flying this over the weekend and I'll test out the rescue function pretty high up so if this rescue tilts the heli to the right I'll be ready, but I wanted to ask if I needed to do anything else.
I have not finished the full set up yet, still need to subtrim tune, set limits, piro optimization, and Geometry tuning.
Scott H
This is no longer an issue. Once I upgraded to the latest download and finished the set up it all straightened out.
Best,
Scott
Oh, perfect.
Thank you very much for the info.
