[SOLVED] backup file from normal spirit to spirit pro ?
Posted: Fri 16. Oct 2015 19:43:30
by icare
hi,
Is it possible to copy a setting file saved from a normal spirit to spirit pro? In order to change a spirit with a spirit pro without to redo the settings....
Re: backup file from normal spirit to spirit pro ?
Posted: Fri 16. Oct 2015 19:51:31
yes, you can do so without any problem. If you are using Banks, don't forget to Save All the banks (3 files) and then to load all files to the new unit.
After loading the setup, make sure that your unit is compensating correctly (This can change) so it is very important to verify it. After this, you have to verify Piro Optimization parameter for correct operation.
Then everything is done.
Posted: Fri 16. Oct 2015 22:07:06
by icare
Perfect, thank for your advice, I will be carefull when I will do that.
Posted: Thu 05. Nov 2015 19:40:49
by icare
ZeXx86 wrote:Hi,
hi,
I replaced a red spirit by a spirit pro on my logo 600, loading the banks of the provious unit. I followed your advice et I checked the compensations : roll and yaw were reversed. However, piro optimization was right.
Thank you!
