[SOLVED] Futaba set up guide
Doug K
I just received my new Spirit Pro. I'll be using a Futaba 12fg and wanted to know if the current Futaba guide, version 1.0, is ok to use with the new Spirit Pro.
Doug
Great!
Yes, it is compatible with Spirit and Spirit Pro.
Doug K
Thanks for the quick reply. I noticed in the 12fg gyro screen there is a gyro2(ail) and gyro3(ele). I have inhibited those and will be using only gyro(rud). I'm assuming the Spirit will take care of those. Is this correct?
Thanks,
Doug
Yes, you are correct. You should use just one Gyro Gain in your transmitter.
To make sure that it is really working correctly, you can verify all channels in the Diagnostic tab.
