Governor limit reached
Scott H
What exactly does it mean when the log says "Governor Limit Reached"?
What should I be looking for. The throttle curve, I verified should have given me a 1000 rpm, I have the max rpm at 2000rpm
I have an rpm sensor picking up one magnet on the main gear (there are two magnets on opposite sides of the gear one pointed positive up and the other negative up)
This is a goblin 700 gasser, perhaps the max rpm can be 2150 or even 2200, but that's not a realistic safe max in my opinion. I wasn't asking for anything near that rpm.
what steps should I take to diagnose this?
GoblinRedB0.4ds
(255 Bytes) Downloaded 131 times
spirit-log-2015-10-20-211437.pdf
(623.27 KiB) Downloaded 141 times
I think that there is no issue. But the log that was saved was from the previous version 1.2.
This mean that at the position of Calibration Finished event there is message about Governor. When the log is created and opened with the same version, then everything should be good.
