I wonder if it was possible to use a tail ESC instead of a tail servo.
If so, what should I take care of?
Regards,
Alexander
Tail ESC possible?
What do you mean by Tail ESC?
Do you want to connect ESC to the CH4 port? What is the reason for this?
Yes, it is possible. But the tuning will be little bit different than with normal servo.
60 Hz should be fine.
You can use rudder endpoints to set throttle range for the ESC.
