Governor on nitro Trex600
lenny53d
I am thinking about putting Spirit FBL systems in my nitro Trex600. What governor sensor should I buy if I'm going to be using two Spektrum satellite receivers?
Larry
Sent from my iPad using Tapatalk
lenny53d
Also what port does it get connected to, and how should it be powered?
You can buy for example Align Sensor and Y-cable so you can power sensor from the Spektrum connector.
Check my attachment, please.
lenny53d
Thank you for the information!
Can I run two spektrum satellites and the governor? What ports would all 3 go into?
Thanks Larry
This Y-harness can be connected to the native satellite connector directly to the unit. Here you will connect one satellite and governor (only 2 leads for powering it). Signal wire from the sensor should go to the PIT pin in the unit.
Second satellite should be connected to the RUD port in the unit via adapter that can be bought in our eshop.
Dawiev
Hi Larry, have you tried the gov on your nitro yet ?
lenny53d
No I haven't, waiting on the governor sensor to come in the mail. I'll post as soon I do and let you know how it goes.
