Hi I have just registered so I can pre order a spirit pro
This would be my first spirit unit
I'm not sure that I've registered correctly
I had already added my home address so was a bit confused with to part that asks
"Please assign an address title for future reference "
I put in "kennyd"
What should I have put in ?
If I order with the above information will I receive my unit through the post ok ?
Kind regards Kenny d
Login
I also made transition from beastx, i had some problems but mostly because i was overthinking everything too much. Allthough the manual is a little unclear from time to time, i think you'll do just fine, if not, there is a forum for questions. Tomas was really helpful with my problems, he's also quick with responses. Good stuff
The address title is used in case you have multiple addresses, you can name them for a quick reference when selecting the one you want, can be stuff like "Home" and "Work".
If we will see any problem with your address we will contact you so the package can arrive without any problem.
Thank you very much for your interest!
