Login
Kennyd
Hi I have just registered so I can pre order a spirit pro
This would be my first spirit unit
I'm not sure that I've registered correctly
I had already added my home address so was a bit confused with to part that asks
"Please assign an address title for future reference "
I put in "kennyd"
What should I have put in ?
If I order with the above information will I receive my unit through the post ok ?
Kind regards Kenny d
zosek
I put "zosek" in there and my unit came to my adress just fine. You should be ok as long as you put your correct adress in :)
Kennyd
Thanks for that
I'm looking forward to trying it out
I have 9 heli's mostly on beastx , I hope it ain't to complicated for an old dog like me lol
A big factor in buying a spirit is the help that is given on here , regards Kenny d
zosek
I also made transition from beastx, i had some problems but mostly because i was overthinking everything too much. Allthough the manual is a little unclear from time to time, i think you'll do just fine, if not, there is a forum for questions. Tomas was really helpful with my problems, he's also quick with responses. Good stuff ;)
Coco66
The address title is used in case you have multiple addresses, you can name them for a quick reference when selecting the one you want, can be stuff like "Home" and "Work".
If we will see any problem with your address we will contact you so the package can arrive without any problem.
Thank you very much for your interest!
