[SOLVED] 1.3.1 failure
Rcpassa
What Do I do next?
When your LED blinks for a while, then only you have to do is:
1. Start the software and then press No when prompted to Demo mode.
2. Select the firmware in the Update tab and press the flash button (you should see Recovery mode label immediately).
3. Connect the battery to your model (with USB interface connected). Then you should see a new flashing progress.
Rcpassa
If it doesn't, what should I do?
Rcpassa
It does not blink...what do I do??? This is getting frustrating.
It is not a problem. I will send you the guide in the private message.
Rcpassa
Did you send it?
Yes.
Rcpassa
Pls check your pm...
Rcpassa
How long should the recovery take?
Rcpassa
Once the unit is plugged in?
