Diabolo Setup?
smsodhi
Hello, these are my Diabolo setup files for all banks.
Bank 0 is the main bank, I have not done a lot of work on the others, but bank 2 is set up with a harder and faster feel.
Diabolo 2.4ds
Bank 2
(255 Bytes) Downloaded 297 times
Diabolo 1.4ds
Bank 1
(255 Bytes) Downloaded 284 times
Diabolo 0.4ds
Bank 0
(255 Bytes) Downloaded 285 times
gabs_mex
Is this for a 550 or 700??
ChrisTTian667
I would be interested in Triabolo 700 Setup too.
I will use the Spirit Pro in the Triabolo, but i assume that makes no difference to a normal Spirit, right?
cheers,
Chris
Triabolo|Kosmik 200|XNOVA 4530 XTS|MKS 960/990|Spirit Pro|REX7
Diabolo BE|Kosmik 200|XNOVA 50XX Tareq|REX3
Settings should be similar, altough configuration of the rotation rate, cyclic gain and cyclic feed forward may be different to achieve similar behavior.
aziz76
When you say similar, are you talking about Diabolo 700 and Triable 700? Or Di 700 and 550?
I am looking for a file for the Diabolo 550.
fernieheliman
I had a Spirit on my Diabolo for a while now , I have to figure out how to post it here ...
or what parameter do you need to know ?
ChrisTTian667
It would be awesome, if Tomàs could add Di-/Triabolo Presets in the next version of the configuration tool. :)
I added my settings for the Triabolo. The Rescue function is not enabled via Bank-Switch but will be enabled via two -100% Mixer in my Jeti DS. I prefer that because the rescue will always work with correct tail gyro settings. I only use the different Banks to switch between different Rollrates.
Tail Gyro is also set via TX.
Idle 1 75% - 1200rpm
Idle 2 70% - 1400rpm
Idle 3 65% - 1800rpm
best regards,
Chris
triabolo2.4ds
(255 Bytes) Downloaded 243 times
triabolo1.4ds
(255 Bytes) Downloaded 269 times
triabolo0.4ds
(255 Bytes) Downloaded 255 times
gabs_mex
ChrisTTian667 wrote:It would be awesome, if Tomàs could add Di-/Triabolo Presets in the next version of the configuration tool. :)
best regards,
Chris
+ 1 to add as preset on the software 550 - 700 Di/Tri
kramrle
+1 yepp that would be great
markrj
+1! Would love to see Minicopter and MSH Protos Max V2 settings.
