Jeti ds-16 setup issues
Please check value in the Diagnostic tab that is going to the unit. What value it is when you enable rescue?
markrj
Hope these will help.
Functions:
Idle 1
Spirit Gyro Idle 1 Rescue Diag Value
Spirit Gyro Idle 1 Auto Rotation Diag Value
Idle 2
Spirit Gyro Idle 2 Rescue Diag Value
Spirit Gyro Idle 2 Auto Rotation Diag Value
Idle 3
Spirit Gyro Idle 3 Rescue Diag does not show rescue activating when in Idle 3.
Spirit Gyro Idle 3 Auto Rotation Diag Value
Thank you very much for the screenshots.
I believe that the problem could be in the first shot (Jeti menu), where you can see 50% in the gyro channel and assigned switch.
As you can see, assigned switch Sa is used as Trim and 50% as trim max value.
I recommend to unassign switch Sa and assign it in the column as in other channels. And also you can delete 50%.
Then I believe it will work correctly.
We are preparing Jeti configuration guide and profiles, so then it should be very easy to setup.
markrj
OK. I will try that and report back.
I used your screen shot from the first page as reference when setting the Gyro sens. Function.
Yes, there are more possibilities, but I think that this way will be better and will not cause any problems.
