[SOLVED] Bluetooth +app not saving changes
velocity90
Nexus is known for its stock Android
-TT E700 V2-Spirit Pro-mks950-980-Kontronik Kosmik 160 HV -Pyro 700 rewound by PD / Voodoo 600 -PD-MX700-470kv--BLS255hv-VBAR 5.3+- Gaui X3+ Spirit Pro
mattbeau
New update on the play store has fixed my problem with my galaxy tab s2. THANK YOU!
Sent from my SM-T710 using Tapatalk
error414
It is good news, I am glad that everything is fine.
Logo 600 3D -> Spirit FBL
Spirit settings Developer
velocity90
Same here :)
velocity90
Did a lot of tweaking today, the dongle works superb! I even forgot to disconnect power of the dongle for 1 flight :) nothing weird happened. Having it dissable power or the wifi signal when starting the heli will make this an perfect addon.
mattbeau
You could use an Rx switch and assign power to Bluetooth with a switch on your TX
Coco66
velocity90 wrote:Having it disable power or the wifi signal when starting the heli will make this a perfect addon.
The question is... what is "starting the heli"?
Motor? No, then you can't make vibe analysis or Governor config...
Flying? No, you have to be able to move the heli...
Possible, but not as easy as it seems...
velocity90
It will come :)
