No pitch; and wrong direction of FBL in case of move
scvflyer
Hi serviceteam,
setting my spirit system (standard) after update - setting channels seams to be fine. Pitch movement is shown at general channel setting as well. But if i try to use pitch under normal circumstances - it doesn't work.
Second - setting direction of each channel has be done and works properly but - if Helicopter will be moved to one site (aileron) Spirit systems moves to same direction - but has to move against this direction
Any idea?
thanks in advance and br
siggi
Adrian
Direction: This can have different reasons, usual if followed installation wizard, this should work.
Causes, Spirit pointing to wrong flight direction or servo plugged in on wrong ports in Spirit.
scvflyer
Hi Adrian,
I fixed one issue - dircection of contra movement while moving heli has been fixed - I set reverse movement in spirit and normal at TX.
last issue - no pitch movement. Pitch traveling is shown at diagnostic tabs from spirit - therfor signal must be known at spirit
Aileron, elevator, rudder, rescue mode works fine.
Thanks supporting me br siggi
jgiannakas
If you're not getting any pitch (collective) you have rescue enabled & active.
scvflyer
Hi jgiannakas,
you are right - I have a mixer at TX and this doesn't work properly (after updating TX Software).
thanks and br
Siggi
