Jeti
Ktm250
I just tried getting my telem working on my Jeti. After going through the set up as per the wilki page, my Jeti will not see the telem Any thoughts.
you have to enable Link-Live feature in your ESC to make it work (and also to enable Telemetry in the Spirit Settings)
It should not suck any voltage normally, otherwise it would be very hot.
Is the Link-Live enabled?
Ktm250
Yes it is enabled in the esc and spirit unit.
Ktm250
Any thoughts.
Can you try to decrease the BEC voltage to 6.6V too (just for try)?
In any way it is really strange. Is your wiring special in some way?
Are you using external BEC, buffer pack or similar electronics?
Do you have a multimeter? If so, you can measure resistance between the wires - when the cable is disconnected. Between signal and red wire, there should be 1kOhm. Between other, there should be nothing.
Ktm250
Nothing special as far as wiring goes. Using jeti x bus with a Rex 7 receiver and jeti muli 6s Lipo telemetry sensor, no external bec or buffer pack. I tested 10k
Thanks!
Yes, it should be 10kOhm - sorry for confusion. So the cable is OK fortunately.
So without the cable, when you connect the throttle cable into the AUX port, it is working. With cable it does not work.
Could you try to decrease General - Throttle/Governor - Throttle Range - Min. by 10 - 50us to see if it makes a difference?
Can you check when the unit was bought? Unfortunately some of the very first units have compatibility issue with the CC telemetry. But we are able to fix it for free.
Ktm250
I did as you asked and I lowered my min value from 1180 to 1130. Still not working.
Please try to decrease the value to 1060us.
In any way it looks like the unit is from the first batch :( Have you other unit that was bought few months later?
So that you can try it with a newer unit.
If this will be the case, we can fix the problem in one day and for free. Unfortunately we will need the unit here.
Ktm250
Ok so I lowered it to 1060 and still the same problem.
